I ran my MMM on 10S
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
I ran my MMM on 10S - 05.26.2009, 06:19 PM
Like the title says. At the track this weekend, I pop two 5S lipos in the truck to practice, I was in a hurry to get to the driver's stand since there was a couple spots open and instead of using my parallel harness, I plugged them in series. The truck ran and I was a little surprised of the power it had.I was at around 1/8th throttle and I was over shooting the biggest jumps
I did four laps before the truck just stopped. I take it back to the pit and realize the mistake I made as soon as I take off the lid. I temped the motor, 212 degrees. I temped the ESC, 146 degrees. I temped the lipos, 128 degrees. I was geared for 40 mph on 4S. I let everything cool down for 45 minutes and put two 2S lipos in series. The truck ran like nothing happened. I hope I didn't weaken the motor or ESC, I'm afraid that I might have some problems soon because of my mistake.
What do you guys think? Other than I was an idiot
No brain, no headaches.
05.26.2009, 06:23 PM
There is a TVS device that is set to trip just a little higher than 6s voltage (~26v IIRC), so you most likely popped that device, but you should have noticed a larger than normal spark when it blew. And the main caps are only rated for 35v (10s is 42v freshly charged). It's a good think component manufacturers design in a bit of overhead, but who knows what else you overvolted!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.26.2009, 06:28 PM
YOU are the LUCKIEST person on Earth!
mistercrash
Guelph, Canada, eh!
Well that's not very encouraging. I guess the smart thing to do would be to send it in for servicing. Question is, am I that smart?
Can I check that TVS device myself to see if it's blown? Would it be noticeable? Where is it located on the board? Lots of questions eh!
Thanks Brian
sikeston34m
sikeston34m's Avatar
05.26.2009, 07:06 PM
Thanks Brian
If it isn't broke, don't fix it. Run it.
05.26.2009, 07:09 PM
I agree w/sikes....run it until it blows....then send it in
shizzon
shizzon's Avatar
05.26.2009, 07:13 PM
you are lucky, i did the same thing and mine died on me!!
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
mkrusedc
NeuMaxx
mkrusedc's Avatar
05.26.2009, 07:18 PM
If it is running fine then as my Dad used to say, "If it ain't broke don't fix it." Do you have a back up if it does die?
mistercrash
Guelph, Canada, eh!
05.26.2009, 07:37 PM
I just ordered one
I couldn't pass it up, on sale at $309 CDN + $3.50 for shipping. Comes to just under $330 CDN with taxes.
Rebelgium
05.26.2009, 08:00 PM
You're pretty lucky indeed, I read the neodyum magnets in the rotor of the motor get demagnetized at 200°.
Appearantly not always :p
Or maybe they partly demagnetized and the motor has become a bit weaker? Hope not.
brushlessboy16
brushlessboy16's Avatar
05.26.2009, 08:13 PM
Wow. That depends on the guality of the motor, good thing you didnt shatter the rotor...
I Say buy a lower kv motor and run it on 10s more often.
crazyjr
crazyjr's Avatar
05.26.2009, 09:08 PM
Castle says their motor will survive 200*, but stick to 175-185 for a bit of comfort zone. You are very lucky, But I'd almost have to try it again
himalaya
himalaya's Avatar
05.26.2009, 11:53 PM
wow it's 30% higher over the MOSFETs' absolute maximum rating, fantastic.
....What a Blue Sky....
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
05.27.2009, 04:37 AM
you must treat your MMM nicely like i do ;)
it's all about the amp draw baby!!....but CONGRATS TO CASTLE ON THIS ACHIVEMENT!!!
and as for your ESC....i'd wait (if you dont have too many races comming up) till it blows up..then see if castle will repair it for you (tell em what kind of feat it pulled off ;) ) and i reckon they would :)
shaun
  Send a message via MSN to shaunjohnson
crazyjr
crazyjr's Avatar
05.27.2009, 08:15 AM
^^ Good point, they might not warranty it, but i'm sure they'd like to see what it looks like, after that
