Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
SpeedAssault
SpeedAssault's Avatar
05.28.2009, 08:44 PM
I would take a scuff pad to the motor and get in all of the little grooves. Then spray light coats of yellow until it iss covered. Let it dry in the sun for a day or so and the take some light grit sandpaper and sand the fins till the al shows back thru. That would look really good with the black endcaps.
Hey thanks, yep LOL I was thinking the same , but man sanding all the grooves, Holy cow. maybe I will dab it with TSP to prep for paint.
your right the black end caps finish the touch of color scheme
I've found Castrol Super Clean degreaser takes off anodizing if you let the parts soak in it. Anodizing isn't that tough it can be polished off pretty easily too. Btw, nice job so far.
Edit: I really like linc's idea, and method.
thanks for compliments
Yea I have used castrol , man is it powerful, it will take paint of car wheels fast. anodize is a chemical bonding, I would not say that is not tough.
I have used oven cleaner on aluminum small part and rapped in aluminum foil, it pitted it something awfull and I watched it and still did not remove all of it./
I found a few search results about anodize removal, but unless you do a proper mix of chemicals other home remedies dont work.
http://www.finishing.com/2000-2199/2076.shtml
thanks guys, I'll post up results
