erevo / flux
exawatt
erevo / flux - 05.28.2009, 09:50 PM
i own a erevo and have a friend that bought the flux. all i have to say is every time we go out he breaks. i actively try to break my revo and the only thing i have managed to break is the rear body mount.
i will say the flux handled much better than i expected however the revo is more capable.
05.28.2009, 10:12 PM
The flux has a few weak points, as does the revo. The flux will be able to handle larger tires than the revo, as large tires kill revo diffs (due to the small 2 spider design).
If I had to choose (I have owned 2 erevos, and 2 converted 3.3, plus 3 savages) I would most likely pick the savage. The diffs are better, and the only drop in diff solution for the erevo are Mike;s hybrids which will set you back 2 benjamins... You can pick up a set of flm or GH 1 piece bulks for the savvy for about 100 bucks, and they will help keep the pinion from flexing away from the ring gear, and allow for good tight tolerances while shimming. Diffs are the worst part of going large scale brushless.
Bottom line, if you plan to race and use truggy lpr lightweight itres, go with the revo. If you think you may want to put some big joe's or large 40 series tires on, go with the savage. I have broken both of them, but the savage gets the nod for durability over the revo. You will never break a savage chassis, and it has a full steel drivetrain. Plus hpi parts seem to be a bit cheaper, IIRC, and the savage uses more common parts front and rear so you can stock less spares. All of the arms are the same, as are the diff bulks, hinge pins, etc.
erevo
exawatt
erevo - 05.28.2009, 10:17 PM
I do run 1/8 truggy tires not the 40s so maybe thats why i have never had drive train issues.
