thanks, no the wheels are yokomo. They are the same pattern as the 4tec though. They were the only zero offset wheel my lhs had in stock, so they will do for now.
If you're gonna be driving in the dark drill four small holes into your tyres. insert some circular flints and glue them in, when the tyres spin they spark :)
There's a guide on the internet somewhere.
Thanks guys! It is not very fast, it is running drift tires. I'm sure if I took out the slydr 8.5 system, threw in an MM and some motor on 3s, and put on some foams or good rubber it would be very fast though!
Anyways I have a question for you or anyone for that matter as far as replacement parts go which are easier to find parts for TC4 or 5 and\or are they interchangable?
