PM me if your interested in it.
443 Kv and a 50:1 reduction box.
Its the same physical size as a neu 2230.
If no i have to put this on my bike :)
Hey what voltage is that motor? It sounds like an idea that wold work well in an application like an E-bike? And where did you get it? off of some household equipment, or junkyard, or some other application? I am curious about the motor to.
heres the ratios and rpms
this is with 24t motor pinion and 54t spur with 1.833:1 tranny ratio and a 30:1 ratio from outdrive pinion to wheel/tire rotation
2200kv castle neu motor on 6s lipo with MMM and 26in tire diameter
-mikey09120
