Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
naynay12
06.05.2009, 06:47 AM
Ok thanks for the info...i would really like to save money by getting 2 3s 3000mah 20c packs,so your certain they won't overheat,nor the motor?Also would there be much power difference between the 20c 3000mah and the 25c 5000mah?
scarletboa
scarletboa's Avatar
07.08.2009, 02:52 PM
i just re-read your post and you want AT LEAST 5000mah packs if you are going to use 20c packs with the CC/NEU motor. it is only $30 for a 20c 3s 5000mah pack from hobbycity. it is labeled as 15c, but it is actually a 20c.
you could use those 3000mah packs, if you were wiring them in parallel.
Tags
brushless, conversion, ezrun, lipo, savage
