glitchy
transtalon
glitchy - 06.06.2009, 04:47 PM
I have a Nomadio Sensor and I accidentally pinch the antenna cable and it began to develop a glitch. I was showing it off with my friend and the buggy is capable of 70+mph and it lost connection with my radio and took off and found it 3 1/2 blocks away. I would fix the problem before you put it out there. I was very lucky my rear upper control arm hit the switch and turn off the controller when it came off the standoff. It didn't hit anybody and it did a few rollover and hit the grass. I broke the front tire and esc but I was lucky.
I would wrap some aluminum foil on the wires that you wanted to isolate from the noise then wrap it with an electrical tape. It looks messy but it works, goodluck.
