Urgeoner
Urgeoner's Avatar
06.06.2009, 06:29 PM
Yes, I do have the balance tap plugged in.
It has an Internal balancer, it is the hyperion eoso610inet...I set the memory params, (Lipo 6s, 1c charge rate, etc..) and when I hold down the enter key to display the balance status, it tells me balancer not connected, but now it does pick up the voltage when I hold the enter button for the battery check ever since I switched the ..and says "Balancer advised!" and starts charging without the balancer..
Is there a certain setting to make it detect the balancer? I've tried both with the little adapter and just the 6s balanceer plugged directly into the machine itself, and it cannot read the balancer either way. BTW balancer is at 44% what does that mean?
