Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
SpeedAssault
SpeedAssault's Avatar
06.12.2009, 01:28 AM
Nodda Emaxx any MO
I got carried away call it a Rev-Osi ! on steroids
06.12.2009, 04:52 PM
That name has a nice ring to it.
SpeedAssault
06.12.2009, 06:19 PM
yea it does huh, it reminds me of Lamborghini's for some reason ,dont know why
The new Lambo Geneva 2010 is AWD and the body is Insanely badass
Wish there was a RC body like this
Name:	2010-lamborghini Geneva.jpg
SpeedAssault
06.22.2009, 02:00 PM
GOOD GOD MAN, This Lipo is HUGE !! Cant wait to Drive this Beast !
SpeedAssault
06.22.2009, 05:38 PM
D A M M Mmmmm
Took it out for a spin and that's what exactly it did
I only had the 1/8 auto cross little wheels so it was dificult to handle at 25% throttle
I better get the 1/5 wheels on there and let this beast FLY !!
SpeedAssault
08.24.2009, 08:03 PM
I DID NOT REALIZE THAT 6S WAS GOING TO BE SO DeSTRUCTIVE !
Updates:
Things broken
Welds on extended steel drive shafts, 5 times
tooth on steel 49 spur gear
Front Diff coller busted
knuckle ball popping out 3 times
Pinion gear coming loose 4 times
Motor coming loose 2 times
Rear shock came off
curb jump collision-- broken body mounts
lost pin in revo shaft
Wheels coming unglued
The car has been very difficult to drive straight once it's reaches over 40mph
so I glued in windows for the rear body as they were cut out from Original owner.
That did the trick along with adding aluminum strips on the bottom of the body also 2 more lower body mounts. total 6
The car now drives straight and is more controllable
cut out vent in front grill and adding tubing to help cool motor/ESC
I took it to the track, hoping to use the track before they closed down and took it apart, but the battery took 1.5 hrs to charge ( charger was hot)
they had already disasemble the track but I drove on the tire marks for a bit, car did much better, then broke the front diff coller that was stock and drilled out to fit the larger losi diff.
A 1/8 nitro racer came over and told me the body is a very poor race body, they just don't well and that my aluminum sway bars need to be steel
Time to make some Aluminum diff collars and steel sway bars
LOOKING FOR Grooved 1/5 tires Please PM mE
littleazn248
11.07.2009, 02:26 AM
Hi there I noticed that you're using a custom chassis what are the dimensions? I'd love to do a similar project. So will Road Rage tires fit in the wheel wells of the body? By the way i also noticed you live in the Bay Area are you part of the M2 Hobbies forum yet?
Thanks
