Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.12.2009, 04:44 PM
If you mesh the gears right you will not strip the 48p.
I'm not worried about gear mesh, but more my shaft size. I've got a 5mm shaft and 32p pinions are easer to find for a 5mm shaft; or can you find two equal tooth count 48p gears, the pinion with a 5mm shaft, the spur fitting in the tc3, and the two shafts about 35mm apart?
