I'm using stock tires, or should I say, I used to use stock tires. They shred way too easily, and if the rubber holds up, the interior foam rips apart. I want to try some new tires, but really want rubber for durability. I would like to find a solid rubber tire, or at least ones that are air filled. Foams makes sense for offroad I guess, but totally useless onroad.
By foams I'm talking about foam rubber
like these http://www.amainhobbies.com/product_...-Dot-17mm-Soft
I have them in the hard compound,they aren't the "grabbiest" but they stay together.
I think I will try these soft ones and just wondered if you had any experience with them.
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
