Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
FG101C
06.16.2009, 12:25 PM
Originally Posted by XXXDAD View Post
Will the Losi outdrives work on this slipper?
Probably, I had to use my Xray outdrives because the outdrives that came with the slipper were not a perfect fit in my Xray. The way the outdrives are cut the front shaft had no play in the outdrive, so any chassis flex would have created some real problems.
Also on your Losi if your using the Losi motor mount the 46 tooth spur will not fit, you will have to shimm the whole diff assembly up a couple mm to prevent the gear from hitting the chassis.
