View Poll Results: Which is the better or recommend brake setup?
Mechanical Braking 4 20.00%
Brushless Motor/ESC Braking 16 80.00%
Voters: 20. You may not vote on this poll
06.17.2009, 11:08 AM
I think it depends on your goals and usage.
If the goal is a simple setup that has as few parts as possible and/or ease of disassembly, then motor brakes is a no-brainer. No servo, servo mounting, linkages, discs/pads, and wires to worry about. And, fewer parts means fewer points of failure. However, the back-EMF spikes tends to be harder on the ESC and batteries.
If the goal is to achieve maximum tuning, then use mechanical brakes. Gives the ability to change front/rear brake bias. However, there is brake fade, not to mention more wear items.
As far as runtime, I think it's a wash either way, or any difference is neglible. This was discussed TO DEATH in another thread and I don't think it ever went anywhere.
If anything, try it both ways and see which one you prefer. I personally voted for motor braking - not because it is "better", but it fits what I use my vehicles for.
