View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
brushlessboy16
brushlessboy16's Avatar
05.06.2009, 09:21 PM
Whats that got to do with the switch though- if you forget to turn the switch off after removng the batts, next time you plug the batts in (without turning the radio on first since due to old age you forgot?) the model would still turn into a run away regardless of there being a switch or not...
Rule #1 in the R/C world is to turn the radio on first, and off last, every time. Funny thing is though I swear the MMM has a built in failsafe of sorts anyway- if I turn the tx off and leave the batts plugged in & esc turned on, the esc leds go to a different color, to indictate 'no signal' and returned the throttle to neutral.
So, switch not required in that sense....
With no signal the esc flashes all three leds and beeps really fast.. or you can just get a dsm receiver which has a failsafe built in. works like a charm
brushlessboy16
05.06.2009, 09:50 PM
Originally Posted by InsaneRC View Post
oh just shut up about it FFS
FFS?
Its a forum- We have just as much right to post what we think as you.
brushlessboy16
05.27.2009, 12:02 PM
Bump..
Kcaz25
Kcaz25's Avatar
05.27.2009, 03:43 PM
Castle randomly emailed me a survey asking if they should change the switches... I voted yes even if it increases the price tag on their units, and wrote in how quickly my switch failed.
fkadir
05.27.2009, 08:40 PM
I got that survey too. Voted 'Yes' to a higher quality switch.
Freezebyte
05.28.2009, 01:18 PM
Mine always lets out a big spark, I just figured it was normal
05.28.2009, 01:20 PM
Your switch sparks?? It shouldn't.
nitrostarter
nitrostarter's Avatar
05.28.2009, 01:26 PM
I only get sparks when connecting batteries....
N. Rustler conversion
Freezebyte
05.28.2009, 02:23 PM
I meant when connecting the batteries.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.28.2009, 06:51 PM
^^ I thought he meant his switch, too. I thought to myself- "Man, that's not right!"
Bar-A10
05.28.2009, 11:27 PM
I vote yes a nice mini deans style jumper would be great.
InsaneRC
InsaneRC's Avatar
06.06.2009, 07:15 PM
Can i Change my vote for yes??
this what happen to my switch the sitch came completey off!! so i had no switch!! and just 2 small wires coming from the circuit board!! Lucky for me some 1 repaired it and soldered the switch right back on the circuit board and it Work!!
So my Vote would have to be YES!!
ethier have the switch be mounted to the ESC like a tab or something like the AE-1 Esc or just have the switch located on the side or no switch @ ALL!!
Mat
Eletric is the New Nitro!!
Traxxas E-Revo
Marui Big Bear
Ofna Ultra LX-1E
nitrostarter
06.18.2009, 02:38 PM
WOW! So I was out running today. I just installed my M11 and spektrum reciever. I went to the track and I started making laps. Then all of a sudden, it started getting glitchy. It was acting as if the power was being shut on and off. I check it out. I had tried to rebind my Tx/Rx, same problems. All my parameters and ESC setting were fine. But it still glitched. Finnaly a thought came to mind, check the switch. I messed with it, and then cut it off and twisted the wires together, and sure enough, everything was fine after that. I'm sure glad it happened like that when I was practicing and not in a race... I would have been aggrivated. So I'll either solder on a new switch like I did my other MMM or just solder the wires together and not use a switch.
