06.18.2009, 03:41 PM
Considering the experience of other uses I would give the hw80 a try with that motor on 3s. Seems to be a solid esc, although I have no experience with them. Plus it has a switching bec so you can run up to 4s without having to use and external bec. The MM does run cooler on 3s with an external bec. Since it has a linear bec any voltage over 6v has to be bled off as heat, so 12+v out of a 3s lipo has to be cut in half, fair amount of heat there.
