stum
06.19.2009, 11:16 PM
If you get one go for the 2200, the 2650 is too fast iMO for racing expecially on 5s lipo. Typically a 13 or 14t pinion is perfect on 4s lipo, going w/ 5s lipo even 12t will be a little fast for racing at a track. Bashing should be fine... you may want to swap to truggy gearing in your diffs to slow it down some... that or like I said go w/ the medusa motor and get a much lower KV to better work w/ your voltage. Use the calculator listed above.
jhautz
jhautz's Avatar
06.19.2009, 11:24 PM
They are both too fast for the track on 5s. get yourself a 1600kv 70mm medusa. Gear for around 38mph and go have a blast.
That Feigao motor is useless for the track. Its a fine motor if you just want to try the electric thing out and see if you like it. But you will never race with it without overheating it.
to make it...
or break it...
Silent...But Deadly
