Help with proline powerstroke shocks -
12.17.2005, 04:38 PM
I filled one of these proline powerstroke bypass shocks for my emaxx with oil (properly) and notice no resistance when I compress the shock. I bled it properly and it oozed excess oil as a screwed the cap on so I know it has full oil. whats the point of a shock if it doesn't have resistance????? any help will be appreciated.:C:
RC-Monster Custom
12.17.2005, 05:16 PM
Err, nevermind, my mistake. You are talking about the bypass shock.
:o
12.17.2005, 08:47 PM
Welcome to the forum maximum.
Does the shock have the right piston or a piston at all in it? It would seem to have some kind of resistance. If none may be something wrong some where.
Peace!
Country
Help support the
Rc-Monster
Buy here
12.17.2005, 08:48 PM
When you were putting oil in, did you take the shock apart of right when you opened up the package just filled them with oil without touching anything?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
12.17.2005, 08:59 PM
Thanks for your replies. I'm new to this forum thing. I don't even have my new emaxx yet and i'm upgrading shocks!!!! I love it!!! Anyway, yes there is a 2 hole "b" piston installed when new. And no, I did not take the shock apart, just followed the instructions to the letter. This bypass shock as far as i can tell just has a wider cylinder and holds more oil. very little resistance when compressed. I sent an email to proline for an answer too. Thanks for all your help, I'm sure I'll have more when I start bashing the emaxx.
12.17.2005, 09:09 PM
does the piston fit snug to the walls in one you have not filled. maybe proline messed up when assembled. I don't really know. I guy named squee has some of these shocks. He seems to love them. maybe drop him a pm. I see If I can get some help for you.
Peace!
Country
Help support the
Rc-Monster
Buy here
12.17.2005, 09:22 PM
well the point of the bypass shocks is to provide extra dampening to help slow the rebound down and help with the large jumps while still having a plush and soft suspension. the bypass shocks are supose to have no resistance. its just like a normal shock without a spring. if you are trying to save weight i wouldnt use them unless it bottoms out real bad.
12.17.2005, 09:35 PM
Or if you want to save weight just get stiffer springs from pro-line or thicker oil.
Losi 8ight e
12.17.2005, 10:34 PM
cool, I'm not crazy!! The kit came with 30wt, but I'll try 60wt on the bypass shocks and that should work. Thanks guys.
12.17.2005, 10:36 PM
I run ue. So I am learning. I like the ue. It works for me. :D Good luck on the proline maximum. Thanks squee for the lesson.
Peace!
Country
Help support the
Rc-Monster
Buy here
12.17.2005, 10:38 PM
Open up the bypass, you need to move the piston up and down, otherwise the outer chamber is not filled..
01.03.2006, 09:58 PM
I've got the Power Stroke shocks and have been quite happy with them. Only changes I've made are 50wt oil and heavy springs. I run the extra heavy in the rear, works great. I've been toying with removing the bypass shocks and seeing how it handles. I know the Tamiya guys ran without them at MMIII. The bypass is subtle for sure but at scale I'm sure it does a lot on compression and rebound to smooth things out.
