stum
06.22.2009, 09:40 PM
Auto-lipo 3.0 is fine, 3.2 if you have junky lipo's but normal packs can handle 3.0 w/o issues as 2.7v is actually when a lipo can be damaged.. 3.3v is overkill and just cuts drastically into your run time as you can't burn through all your packs mAH before hitting a LVC.
Punch is a tricky one.. if you put on too much punch you loose throttle control while you are in the air, if you do too little it can make it hard to get traction really fast.. I typically set mine at 10% to 20% never more, even at 30% I find you loose just a little too much control while in the air (gas'in up to level out).
I do always set my timings to low (5), Zero drag brake (causes more heat than good), and to be honest I use the mechanical brakes so I disable the brakes and reverse completely.
Runs great, and the only thing that keeps me from winning at the track would be my skills :) LOL Getting better but still not up to the top 2 or 3 drivers yet... closer all the time though.
