zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.23.2009, 12:05 AM
and an arse end pic
Wires are all 10awg... kinda ran into trouble with the input leads as it was pushing against the case, so I had to grind away a section so it would sit properly. Cap bank is made up of 6 35v/330uF low esr caps, the same cap bank from the "FrankenQuark". I also used thermal adhesive on the heat spreader as you can see.
