The easy way to fix your brake servo is to turn the linkage around(attach brake linkage to the other side of the servo horn). no need to mess with the wiring and stuff!
Make sure you have any channel mixing disabled, too.
I tried to use an MGM plane controller in a car once...it was not good at all! I didn't have mechanical brakes or anything, but it certainly is not ideal software for land vehicles.
