Frozen72
06.23.2009, 11:52 PM
OK so setting my LVC higher would be the best way to make sure the batteries are always in sync right?
Should I get a 750kv or 880kv?
750kv on 44.4V = 33,300RPM
880kv on 44.4V = 39,072RPM
750kv seams like the way to go because if needed I could gear up and chances are everything would run cooler because it would also pull less amps and still give me 5HP.
