mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
06.24.2009, 11:26 AM
I really thought I had it right you bubble burster
I figured that to get the output in amps it is: Mah capacity x C rating / 1000 = output in amps. So if I have the output in amps and I want to get the C rating I would go (amps X 1000) / lipo's mah = C rating.
I don't get why I would get 1 as an answer. For example, if I get an output of 98 amps, I would go: (98 X 1000) / 5000 mah = 19.6 C.
You're confusing my simple little brain Brian.
No brain, no headaches.
