06.25.2009, 10:09 PM
As long as you have the balancing connector connected you should be good to go. You do need to be in balancing charge mode, but the instructions should point you in the right direction.
The mode button should allow you to swap into the balancing screen when you are charging and the up and down keys should allow you to view each cell individually and all of them as a whole.
This info is based on the hope that the 720i works like the 610i...
