Jason
06.26.2009, 11:56 PM
here my shock setup it wont work better then the stock shock for me .. when I run over bump the rear end goes up in the air and sometime flip and it REALLY dont do jump fine...
front shock is electric revo aluminium body and titanium shaft white soft spring with piston black 2 holes and AE 35WTS SHOCK OIL.
rear shock is front jammin X1-CRT shocks with white soft spring + white 2 holes piston and AE 50WT SHOCK OIL.
Jason
06.28.2009, 09:21 PM
rhinopole
10.15.2009, 05:45 PM
Does anyone know if these will fit?
http://cgi.ebay.com/NEW-2-4GHZ-REVO-...item1c0ca515d6
Thanks.
GO-RIDE.com
10.15.2009, 07:52 PM
Thanks.
Those will fit, but you will need the softer Jato springs.
E-8ight - Tekin RX8 2000kv/4S
BUSAFIED
10.19.2009, 11:36 PM
there's your prob right there, Jason...
for the revo front shocks, use the Jato pink springs and the #2 piston. You can vary your shock weight from 25-27.
In the rear, use the soft springs for the buggy front and use 25-27 weight oil.
Another option that I found that works pretty darn good is using 1/10 Stadium Truck shocks (preferably aluminum) in the rear with the .5 blue springs and about 35wt oil.
feel free to PM for further info. :thumbsup:
