nitrostarter
nitrostarter's Avatar
06.29.2009, 12:10 PM
That's what I've been trying to get at, but some people will still fall for the over rated product. People fail to understand simple electronics. One rule that I like to go by is: What ever the continuous rate of a ESC is, use it as the max cont. burst for hard accelerations only. A few smart ones knows best that there's no bloody way any small ESC can deliver anywhere near 200A on a continuous bases. With that said, Castle Creations, Tekin and a few of others will not over rate their ESC like many do. So yes, the hobby industry does need a standard to be set, but we also need the manufacturers to come clean as well.
There should be some standard and I think the mfg's you mentioned do follow this. However the problem comes in with these knock-off companies that make something that works ok and then bogus numbers fly. When I was boating heavily, their was a claim on a Hobbycity esc of 2-6s capable, but when questioned, they stated the ESC shouldn't be used on more than 4s applications....
N. Rustler conversion
