06.30.2009, 12:16 AM
Always read the forums but never posted...
Anyways,
I have a 3s 4900 20C Rhino battery and when I charge it it only takes in about 1500 -1700 mah after I ran. I charged the lipo up again and ran it to about 11 volts where it started to slow down. The second time I charged it was on a hyperion that I borrowed to check the cells. It was fully balanced at the end of the charge. I ran it this time and it did the same thing. I was told to charge the individual cells and the mah added up to around 4500 but I did not run until cutoff and it only charged to around 1500-1700 mah again.
What a mouthful, but do any of you guys know what is going on?
Thanks,
Zach
06.30.2009, 12:18 AM
Hmm, sounds like you have a bad cell on that rhino pack. Can you set your lvc to 3.2v per cell and give the pack a full run till the lvc kicks in? If the charger only puts back 1700mah that is all you have used, not even half of the pack...
06.30.2009, 12:22 AM
I did not mention that but it has always been set to 3.3 volts per cell. I ran it to cutoff the run before it only charged this much.
06.30.2009, 12:23 AM
When I charged it it does not even start charging at 4.9 amps like my other batteries do. It starts at about 4.2
06.30.2009, 12:24 AM
You must have a bad cell. It is dropping voltage badly, and letting the pack voltage get low enough so that the lvc kicks. I can pull the bad cell out, or at least test the pack, but it may be cheaper/easier to just buy another pack, those packs are about 40 bucks new...
06.30.2009, 12:27 AM
I have a neu energy pack that should be here tomorrow but I was just seeing what could be wrong. I figured it might have had a bad cell. I have only had it since january and have only charged it about five times a week sometimes not using it some weeks.
06.30.2009, 12:36 AM
Originally Posted by lincpimp
Ahh, I see what the "gimpy" refers to... I give you alot of credit for having a sense of humor, not sure if I would be able to handle that myself. Respect! (said in Ali G voice)
Eh, I've got an awesome wife,7 month old twins(Grrr. go back to bed) 2 Good Dobies(kinda) and I still get to play with toys at my age.
Lifes to short to dwell on the speedbumps, you gotta keep on truckin'
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
06.30.2009, 12:47 AM
Good way to look at it! Glad to hear you have a great family, that can cure all ills!
06.30.2009, 01:05 PM
hey linc i got that 5s zippy 5000 pack h pack u fixed for me but my application in the muggy is too much for it and i puffed a cell pretty good it goes away but after i charge it and run it i comes right back and the pack is running hot, but i have a 10th scale staduim truck i was wondering what it would cost just to split the pack into 2 2s packs as im going to need a good pack for the muggy which has been almost bombproof on 5s but am looking to get a 1900kv motor rather than the 2200 and run 6s for less strain on the system
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
"1.21 GIGAWATTS!!!"
06.30.2009, 09:22 PM
Linc,
your pretty good with soldering..(duh:)) and i was wondering if you knew how they made these...and if it could be done with the existing male/female plugs i have.....
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNKY8
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
06.30.2009, 10:13 PM
Originally Posted by hootie7159
I have made those before. Just tin all of the tabs, and figure some method to hold all 3 of the plugs together when you solder them up. Pretty easy.
"1.21 GIGAWATTS!!!"
07.01.2009, 12:50 AM
do you use plasti-dip to insulate the joints as well???
Losi SCTE
MMP/1410 3800kv
Dx3s
07.01.2009, 12:54 AM
I made some adaptors similar to that and I just use hotglue to insulate them. Doesn't look the best, but works well. If it can't be fixed with duct-tape, then hotglue is the next best thing.
07.01.2009, 01:20 AM
Yep, as long as it insulated and doesnt allow shorting out, then it doesnt matter how ugly it is.
07.01.2009, 09:46 AM
+1 on hotglue. I used epoxy for the first deans parallel adapter and it was a bitch to keep it where I wanted it to stay, kept running out. I like hot glue for various projects, especially sticking wheel weights on, works like a champ for that.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
