Motor play?
montyjcm
Motor play? - 06.30.2009, 10:41 PM
Hey everybody,
So, I was replacing a spur gear today and noticed that the shaft on my motor (MMM 2200kv) had about 1mm of play (along the shaft length). I also noticed that there was a fine coating of red dust layered close the the pinion location, on the motor plate and motor. Is this normal wear and tear? Should I be concerned about the shaft play?
This is on a e-revo, btw. I had stripped my spur gear previously (too tight of a slipper I believe)
Thanks for the help!
