Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Ryu James
Ryu James's Avatar
07.02.2009, 02:27 PM
Ok, had a look for a 12mm bore, hubless, mod1.5 steel gear. Came up with this:
https://sdp-si.com/eStore/PartDetail...70&GroupID=591
Here is the pdf info on the gear familar, just look at the 36t hubless info in the 1st table.
https://sdp-si.com/eStore/..%5Css%5CPDF%5C78501072.pdf
At 22 bucks plus shipping it is not too bad. Diameter is 57mm on the 36t gear, so not sure if it is too big to fit with the stock center bulkheads...
If those links do not work, search sdp si on google, and put this part number in their search feature: A 1C 1MYK15036
Linc, you are the f-ing man!!
that should be perfect. the stock bevel gear is 54mm. i could probably get a gear as large as 60mm and be fine. that 40t might even fit but i already ordered the 36t one. so now all i will have to do is have my machinist drill 4 holes and in 5 minutes i have my spur gear. woo hoo!! and Mike said his pinion gears should be available for sale by Monday. 11t to 22t pinions! sweet!
cant wait!
assuming this works the next aspect to be tackled is the mechanical brake setup. i have already orded some parts for this and have an idea of how to make it work so i will post some pics when the parts arrive. probably wont be til monday.
Photobucket
36tspur2
36tspur1
Jammin SCRT10 Neu 1512 1y
KaztheMinotaur
KaztheMinotaur's Avatar
07.02.2009, 05:44 PM
Are you going to mount the motor to the front? If so where are you going to relocate the radio gear to?
