The "I'm Bored" thread
Metallover
RC-Monster Spudgunner
Metallover's Avatar
The "I'm Bored" thread - 07.04.2009, 01:38 AM
I'm Bored. I made a thread. Here you can post random crap or photoshopped pics or regular pics or games or videos or links or whatever.
I made an item search
FIND:
-A brushed motor
-A RX (not on the micro T)
-A Center diff
-2 Hobby knives
-A pencil
-13 screwdrivers
Oh yeah, I made a handle/trigger for the spud gun today. It has a tazer ignition, so after I broke the switch in that (on accident) I extened the wires and got a momentary pushbutton switch.
07.04.2009, 01:43 AM
Found all of the items.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.04.2009, 01:44 AM
I found everything. Let's make it challenging next time. I'm still bored!
07.04.2009, 01:45 AM
Me too!
What's_nitro?
07.04.2009, 01:48 AM
I have one- Let's play "Count the Dean's Plugs"!
I count 8. Hmm???
07.04.2009, 01:51 AM
I count 8 as well.
Metallover
Metallover's Avatar
07.04.2009, 01:58 AM
OK I'll make another one
FIND:
My parent's names
2 sawhorses
Count the PB jars
A tennis ball
2 drills
A slingshot
A bike lock
A rear pneumatic scooter tire
A weedwacker missing a part
An orange nerf dart
A pinecone
saftey goggles
Metallover
Metallover's Avatar
07.04.2009, 02:00 AM
I count 8 as well.
oooohhhhh, the "2" in the connectors/electronics bag are actually 2 pairs, making 10 total.
What's_nitro?
07.04.2009, 02:07 AM
I counted the pairs as 4 total. I missed the one behind the Tx, and apparently one somewhere else....
Metallover
Metallover's Avatar
07.04.2009, 02:10 AM
The two on the left are part of a parrallellaell adapter and the third plug of the apparatus is barely visible.
Without double posting; lets play "What the hell is this?!"
So what is it?
07.04.2009, 02:40 AM
bat turned into a torch.
still bored.
parallellallellellallel
brushlessboy16
brushlessboy16's Avatar
07.04.2009, 06:51 AM
So what is it?
that is definitely a sodemizer....
07.04.2009, 07:15 AM
how do you definitely know that?
Foxracin
07.04.2009, 09:40 AM
Ahahha I have a tazer on my tater gun too. Sweet. Works a hell of a lot better then a grill igniter.
Metallover
Metallover's Avatar
07.04.2009, 12:03 PM
Let's discuss spud guns. I'll make a small guide on how a spud gun should be made.
http://www.burntlatke.com/
Materials - Pressure rated pvc ONLY. ABS makes shrapnal and fails easier then pvc. Use pvc primer and cement ONLY. Let it sit overnight before firing. I recommend 1.5" for the barrell and 4" for the chamber, although I've used 3" and it works. I like 4" better though.
When designing, make sure to make a gun with the correct C:B ratio. (Chamber:Barrell) If the Chamber is too big then the shot will be loud and there will be wasted energy. If the barrell is too big then the shot will be quiet, but friction and suction will slow down the spud.
C:B calculator - http://www.burntlatke.com/ratcalc.html
C:B graph. This is using propane, and the optimum C:B ratio is .5:1 to .9:1. I think .8:1 is the accepted best overall ratio, and I use about a .7:1 so it's a little quieter in the city.
C:BGraph
For fuel, the best were found to be propane (metered) and the best aerosol is aerosol starter fluid. When using propane, you could take a torch and squirt some in without measuring it, but the educated way is to use a propane meter.
Ignition - The old BBQ ignitor works, but a stun gun is a wonderful investment. You will also want to look at a flint sparker for a lantern too. Check out the Sparker Reference Guide I've found another ignitor too - http://ultimatespudgun.com/product_i...roducts_id=219
I've bought two $16.19 shipped stun guns off of ebay. They work great and provide a large, helthy spark. They're called "STREETWISE STUN GUN". I looked now and found one for under $16 shipped. Just a heads up you'll have to open it up and disable the alarm because it a loud mofo.
Chamber fan - this is optional, but it vents exhaust gasses and circulates the fuel better, providing a better ignition.
So things to consider are ignition system, fuel system, chamber fan, and maybe a handle/trigger. I'm so bored, I'll post a link to the tazer review I took pictures for after I write it.
