KB45-17XL in a 1/5 FireHammer M/T
aqwut
Brushless Heavy Weight....
aqwut's Avatar
KB45-17XL in a 1/5 FireHammer M/T - 07.05.2009, 08:05 PM
Hey Guys,
I know I started a thread about making a brushless firehammer M/T a few "Years" back.. I haven't started it, until yesterday. Yesterday, I was bored and thought, "What if I stick a KB45 in a 1/5th scale just for kicks". Well, I now have a firehammer M/T powered by 8S & 12S 25C 5000mAh Enerland Lipos. It ran decent for a $55 motor.. hahaha.. I'm sure the 2280 has enough balls to power this thing up. It looks a bit ugly, but I didn't have a big enough sheet of aluminum. All I had were Angled Aluminum which I had to cut one side off of it. I will have upload a video later. here are some Pictures.
http://www.youtube.com/watch?v=pkiC1U-nclo
http://www.youtube.com/watch?v=mc3Lbpw3KLo
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
07.05.2009, 08:09 PM
I love the size of the 7th scale more so than even the 1/8 stuff. I am just skeptical about getting one for a couple of reasons...
1. durability
2. part support
3. cost of converting one to elect. ( bigger batts, motor, etc..)
your conversion look really good and look forward to your vid.
KaztheMinotaur
KaztheMinotaur's Avatar
07.05.2009, 08:49 PM
What ESC are you using?
aqwut
aqwut's Avatar
07.06.2009, 02:14 AM
The Older Sentilon ESCs....
Videos Added.. I will try 12S tomorrow...
nitrostarter
nitrostarter's Avatar
07.06.2009, 07:37 AM
Beware of the killer pooch!
N. Rustler conversion
07.06.2009, 12:24 PM
Looks great aqwut... You hardly get any traction on the street... How are your temps?
aqwut
aqwut's Avatar
07.06.2009, 04:28 PM
ESC was ice cold... Motor was about 60 Celcius... Batteries... cold.. I think this motor is being pushed too hard.. LOL.. I will try 12S in a bit....
nitrostarter
07.06.2009, 04:51 PM
You should have asked to pull that kid in the wagon around. That would have been fun.
Looks like 2WD is doing some spinning and tailing out?
07.06.2009, 07:27 PM
Cory...
The motor is already stressed pulling around a 25lb truck, last thing it needs is 60lb extra on its tail...
aqwut
aqwut's Avatar
07.06.2009, 09:18 PM
Cory...
The Truck is about 20Lbs... Feels lighter than it was with the Petrol Engine with Fuel in it...
Here it is on 12S1P 5000mAh PolyQuest XP 25C
And here's a Video on 12S
http://www.youtube.com/watch?v=SBV_tFWnU_4
07.06.2009, 11:56 PM
Looks like that kb has plenty of torque to push that truck around. What top speed are you geared for on 12s?
Some closer pics of the motor mount with the cover off would be nice too!!!
blueb8llz
07.07.2009, 12:21 AM
nice backyard. nice conversion too
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.07.2009, 01:09 AM
is it just me, or do I see a disc brake in the front wheel on that beast?
07.07.2009, 11:49 AM
Runs better with 12S. If you've got a lower kv motor and an esc that could handle it, go 16S!
ZPB: Yep that looks like a disc brake.
aqwut
aqwut's Avatar
07.07.2009, 12:24 PM
LOL, 16S would be nice if I had the controller for it.. heck, I'd run 20S if I could...
I rigged it up so if I do brake anything it will be easy to replace with stock Duratrax parts. And it's geared for 57MPH on 12S and 38 on 8S.... most/all of the parts are from the original Duratrax part... The motor mount was so easy to make.. I'll take a snap of that maybe tomorrow for you guys.. Pinion, I used the 14T 10mm bore transfer gear from the firehammer.. and for the 6mm ==> 10mm sleeve I used the support inserts which supports the petrol engine.. Worked out perfect!! I'd just have to bore it out to 8mm when/if I put the 2280 in...
Yeah, I have the front wheel disc brakes, I haven't mounted it on yet, only the discs.. I'm using the rear disc brakes on the shaft.. but I will eventually go to all around disc brakes to save my transfer gears and Differential...
