johnrobholmes
johnrobholmes's Avatar
07.08.2009, 07:29 PM
Looks about right to me. I like the idea of using a hub for the jackshaft. Motor to big ring, freewheel to rear hub. I am getting some ISO disc mount to chainring adapters made right now, it could allow you to use a bolt on front hub for the rear with a few washers.
Keep in mind if you use a freewheel to drive the rear, it will need to be left side drive when the freewheel is a normally right side. It goes from being normally driven to being a driver of power.
---JRH---
