himalaya
himalaya's Avatar
07.09.2009, 02:29 AM
Courtesy of Mark (mkrusedc):
Originally Posted by mkrusedc
The first two numbers of a Neu motor designate the diameter. For example the 1500 series has a 15mm rotor.
The 15xx Neu has 18mm dia. rotor.
....What a Blue Sky....
Semi Pro
Semi Pro's Avatar
07.09.2009, 06:02 PM
well all i can add is that i have been very happy with my tekno neu
mkrusedc
NeuMaxx
mkrusedc's Avatar
07.09.2009, 09:56 PM
Yea Brian pointed out that it is the rotor/stator? not the can.
starscream
RC-Monster TQ
starscream's Avatar
07.10.2009, 03:04 AM
My cc 2200 ran much hotter than my neu motor. cc 2200 consistantly ran ~140 deg F
My T8 2050 motor barely breaks 100 deg F
Ha Ha
Patrick
Patrick's Avatar
07.10.2009, 03:34 AM
Rotor is the magnet. 15xx doesn't refer to the magnet it means 1.5" stator diametre.
I don't think the holes in the neu's can are the temp difference between neu and cc motors. My Tekno 1515 1y (no holes in can) doesn't run noticeably different in temp on 4s, compared to my standard neu 1515 2.5d on 5s. Same car, about 1000rpm difference, same gearing, same race tracks, same type of cells.
Kajman
Kajman's Avatar
07.17.2009, 04:39 AM
Is tekno neu square motor made by neu or i is it like cc neu, only neu design? I think of square 1515 1y tekno neu or just 1515 1y neu - the firs one is cheaper, so what is your idea?
himalaya
himalaya's Avatar
07.17.2009, 06:39 AM
Sorry, I measued again last night, the CC Neu's rotor dia. is 19mm. 1mm thicker than the original Neu, as I remember we've discussed somewhere in this forum.
teknorc
07.17.2009, 11:40 AM
The square can motors are genuine Neu's, made here. Only the can is different.
Tekno RC - Performance Parts
Kajman
Kajman's Avatar
07.17.2009, 11:45 AM
Thank you man, are their rotors same diameter as neu too? I can see cc neu is not exactly the same...
nitrostarter
nitrostarter's Avatar
07.17.2009, 11:46 AM
there's your answer.
N. Rustler conversion
Kajman
Kajman's Avatar
07.17.2009, 11:51 AM
Ok, just wanted to be sure. BTW, square can is perfect idea :)
