07.12.2009, 11:58 AM
Thats what I thought.. Mind you, that is according to the numpty on the HPI forum who blew up his flux the other week, so it'd be nice to hear from a Castle dude about said data recorder.
TexasSP
Something, anything, nothing
TexasSP's Avatar
07.12.2009, 01:25 PM
Better hush hush on the black box or the unmarked black suv's will be pulling in front of your house soon......
www.cubicle101.com
jpoprock
"Don't act like you're not impressed."
jpoprock's Avatar
07.12.2009, 02:43 PM
Honestly... I think that run I did on the gravel, with the Moabs... is what did the ESC in. I shut it off in the nick of time (unknowing anything was wrong), then when I drove lightly around the yard in grass, the caps let loose from braking. Not OVER braking, but just regular braking. The ESC just couldn't take it.
A friend of mine fried two MMM V3's (not fire), from driving them in sand he thinks. So, I gather that sand is NOT your friend with a BL system huh? I can't believe how touchy these MMM's are. Overgeared, too much braking, sand, low C rating, etc causes failure. I get it that there are certain basic rules that have to be followed.... esp when you're pumping 6s thru the thing. But now I'm going to be all paranoid when I get my new one back, and I should have to feel that way.
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
07.12.2009, 03:01 PM
TBH: I don't like running ESCs to their max voltage value. There just isn't enough headroom for me. The TVS on the MMM is rated for 26v IIRC, and at 6s, a system can generate enough EMF when braking to stress it and blow it. And when the TVS blows (which is probably not noticeable to the user), all that EMF energy is no longer being clamped and the FETs, caps, and batteries have to cope with it instead. I like to run 1s below the rating, so, for the MMM, that's 5s. No problems so far on either of my two MMMs. Even on a Quark (which is rated for 6s too), I run 5s max in any of those systems, and those have been solid.
The only ESC I run at over it's advertised spec is the MM (on 4s), but that is because I feel it is underrated. 25v caps and 30v FETs. The only limiting factor IMO is the built-in linear BEC, which is easily remedied with an external switching BEC.
Should the MMM be totally reliable up to its rated spec? Sure, but as said, everything has to be "ideal" when running that close to the edge. Any one thing out of whack can cause "issues" as we've seen. Why is it that some people (maybe the majority) can run fine all day long on 6s? I dunno, maybe they are lucky, happen to have cream of the crop components, or simply not as hard their stuff.
e-mike
e-mike's Avatar
07.12.2009, 03:49 PM
¸¸¸¸ I don't like running ESCs to their max voltage value. There just isn't enough headroom for me. The TVS on the MMM is rated for 26v IIRC, and at 6s, a system can generate enough EMF when braking to stress it and blow it<<<<<<.
castle should put a higher devise to prevent some failure????
D8t on juice!!
07.12.2009, 04:56 PM
FYI back voltage is a lot more than that the HV BEC can take 50v input for non braking air use but only 6s in cars due to voltage spikes under braking...
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
07.12.2009, 05:47 PM
these type of failures MUST be caused by setups
i cant get my MMM over 150 (fan is on very briefly after stopping) under HARD load and on 6s.
but i also USE the punch control and the throttle curve so no standing backflips for me, it will wheelie if i mash the throttle but i avoid that cause the tyres cant take it (center diff)
my motoer never even hits 120 and it's geared for 45mph on 6s.
i wanted to go up to 40 series on the reace truck...but needless to say gearing down is on order, but then regen brake load is increased from the extra enertia.
and personaly i have never heard on anyone killing one of the castle/neu 2200's from overheating
kinda need a recomended setup in the boxes of traxxas and HPI since both company's are speed obsessed but in reality, unless treated nicely and you are running great lipo's then the future looks overcast...
and the standing backflip video's on HPI's forum...they cant have possibly done that geared for 70mph
07.12.2009, 06:08 PM
It's like anything else that is high-performace; cars, computers, audio, etc. The closer you run to the edge of the envelope, the more chances for failure. Most people who fit this category understand this and expect failures, but these systems are made available to the average joe who thinks they can open the box, plug in any old battery, and gear to the moon for subsonic speeds. And those same people wonder why things fail.
I agree though, TRX and HPI should definitely provide recommendations for various uses along with warnings if the user departs from those recommendations. The trouble is that there are so many variables to account for; tire size, drive style, ESC settings, battery quality (real-world, not whatever sticker the manufacturer decides to slap on to improve sales), voltage, and so on. Would make recommendations either too general to be effective, or too detailed for people to follow.
It's nice that HPI and Trx has these systems available right out of the box, but I don't think the masses are ready for it TBH.
jpoprock
jpoprock's Avatar
07.12.2009, 06:46 PM
Hey guys... I can't take any pix, cuz my camera is at the in-laws! But I pulled my Neu the other day to take a look at it, and noticed something peculiar. Here is a picture from Neu's site showing the copper wires:
http://www.neumotors.com/Site/Picture_gallery.html#1
Well, on MY Neu 1515 2.5d /f, a particular section of winding is much darker... almost brownish black in color, and the other section of windings is the copper color. Like a 1/4" braid. If you took both colors and wrapped them like the picture shown. 1/4" section is copper, the next brown, the next copper, the next brown.
What could this mean?? Could that ESC fire have somehow burnt up my motor? Or did something go wrong w/ the motor causing the ESC fire??
I NEED MY CAMERA!
07.12.2009, 08:42 PM
Bad motor > dead esc, not the other way in 99% of cases I've seen around here. Seems more like you may have gotten something nasty inside your motor, that caused a shorted phase > cooked esc. Running in gravel you say? With a motor that has lots of holes in both ends?... (Im a bastard, but at least I try to be humerous at the same time....).
hemiblas
hemiblas's Avatar
07.12.2009, 10:44 PM
I have been running my MMM on 4S and 5S for a while now with no issues with all types of batteries, motors and configurations. I do a lot of hard starting and stopping and havent had any issues, mostly bashing. I decided to try some 6S setups conservatively geared just to test and have now gone thru 2 controllers in 3 weeks. The same controllers that were operating perfectly at 4S and 5S did not work on 6S for to long. In both cases the controllers failed while the truck was coming to a stop. The second failure took out one of my lipos. I will be sending the second one in this week, but I am pretty sure that if you are using the MMM on 6S and using the ESC for braking, I think the probability of failure goes up quite a bit. Maybe I am just unlucky twice this month, but it just seems like to much coincidence that this would happen. My solder connections were solid in both cases, no binding on the truck, I really have no other explanation as to why this could happen. AFter reading Brians post above it makes sense. On the second controller I could see puffs of smoke coming out as it came to a stop at my feet. I was braking hard as always with the 40 percent brake setting so the truck doesnt flip over going forward.
Unsullied_Spy
Unsullied_Spy's Avatar
07.12.2009, 10:51 PM
I managed to kill mine in my Muggy under really hard braking. 80mm Medusa, 16/46 gearing with 40 series wheels/tires, 4s lipo, and it took repeated hard braking for it to finally stop working. No drama, it just stopped working right as if I had burned out a phase. Got my replacement and it's still going strong ~4 months later.
07.12.2009, 10:53 PM
Originally Posted by e-mike View Post
...castle should put a higher devise to prevent some failure????
Maybe, but that would involve a total redesign. Not sure if they are willing or see the need for it. As long as people understand the limitations, 6s should be ok.
Besides, the reasons I stated are just MY opinions/theory. It doesn't mean they are correct. But, the evidence sure supports it. How many 4s or 5s setups have you heard of flaming up vs 6s setups? I'm sure there are some, but those are probably just the normal statistical failures.
hemiblas
hemiblas's Avatar
07.12.2009, 11:15 PM
When I get my controllers back, I will be going back to 4S and 5S setups, but I agree, Castle should maybe look into this to see if there is anything to your theory. It may help to explain why they get some of their controllers back for warranty work. After my experiences this week, I think you are on to something too. So basically this would also apply to heavy vehicles on 4 and 5S setups.
muted
07.13.2009, 03:33 AM
Originally Posted by fastbaja5b View Post
Was this on 4 or 6s lipo?
Yep it was on 4s. The battery is a Zippy 4s1p 3500mAh. Stickered as 30c
