zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.12.2009, 09:18 PM
Yikes, those Harris packs are way overpriced.
Yeah, I would love to see some Zippy flightmax eagletree graphs. So if anyone has recorded a zippy session, then come on and post er up!
I can't see them performing very well, I wouldn't hold my breath about the idea that they are overrated packs for a great price.
sikeston34m
sikeston34m's Avatar
07.12.2009, 10:08 PM
I have a cell logger setup on the way that works with a program called Logview. It's not exactly an eagletree, but should be interesting to monitor cell voltage under a load. It hooks up to the balance lead and records individual cell voltage. Handy for spotting troublesome cells I would think.
ZPB, I wouldn't sell the flightmax or the Turnigy short. I've ran both.
My E Revo is set up this way.
MMM ESC
Medusa 36-60-2000kv geared 18/52
I know this setup doesn't draw as much as the Castle Neu does, but it has allowed me some comparitive testing.
They're not bad at all. I will be able to do some comparitive cell voltage reports under a load when my cell logger gets here.
I have several different brands that will be put to the test.
zeropointbug
Z-Pinch racer
07.12.2009, 11:14 PM
It's just that I have never seen a discharge graph for one...
I would like to contact many of the mainstream manufacturers of RC packs to get them to give up one of each of their different C rated packs, then do exhaustive testing and to determine a standard performance rating, like we mentioned in the other thread. I would love to do this myself, as I have some good equipment already, and would only need a few pieces here and there, and I have a professional test setup.
sikeston34m
07.12.2009, 11:32 PM
What is amazing to me is:
It seems each Lipo manufacturer is playing around with the slurry "recipe".
I've ran the cheap slurry compounds. They tend to not hold voltage well under a load and toward the end of the run, you know the end is coming. It's still running but it's starting to get tired. This lasts for a few minutes.
The better slurry compounds, higher "C", behave somewhat differently. They hold their voltage well under a load, quite high. When the end comes, it's like falling off a cliff. One minute, you're running strong, and then it's on the LVC.
Pack Temperature often gives you some indication as to how hard you are pushing the pack. This "rule" doesn't seem to hold true for the flightpower compounds. They have some incredible punch, but seem to run warmer than the rest of the herd.
zeropointbug
Z-Pinch racer
07.13.2009, 12:03 AM
Maybe their Coulombic efficiency is not very high? I am still wondering if this efficiency is converted into heat, or if I am off base with this..?
I have seen one video on youtube where they test a flightmax 20/30C 2200mah pack and the voltage drops to 3.05v/cell @ 26C, which I guess isn't too bad, and might actually be on target for a 20C rating... but I would like to see the same kind of test for the 30C packs. Cuz don't get me wrong, I am very interested in these packs, I just have not seen any data showing they deliver as advertised.
Where as I did a bit of research on the Hyperion G3 35C packs I bought, and on RCGroups, and helifreak forums they did some good tests and they really do deliver amazing power, and just a touch off the 'ultimate pack' Thunderpower 40C batteries, but for almost 1/2 the cost of the TP.
Like you said Sike, these G3's are delivering the power right up until the end, much like A123's in fact. From the few tests I did of my own, I found they would deliver around 3.35v/cell at 35C discharge, maybe higher. The one temp reading I ever took was at the track, someone else's gun (lost mine), the temps were only ever 5F above ambient temps... that's impressive.
I suspect Flightpower is using the same cells in their EON X30 packs, as they state VERY similar benefits for their 'new' packs over their old ones. Neu I think might be using these cells as well, along with CTech batteries.
zeropointbug
Z-Pinch racer
07.13.2009, 12:18 AM
Maybe your eagletree logger is not calibrated/inaccurate?
Patrick
Patrick's Avatar
07.13.2009, 05:43 AM
It's an Australian site (I'm pretty sure), so stuff like that is a bit more expensive here usually, but manly it's in AUS$, which got up to 97US cents around this time last year, but is down to a bit under 80US cents now.
I wonder what types of cells the 30C packs use. I remember hearing a while ago that some of the 30C packs didn't hold voltage quite as well as the older 25C cells of the same brand.
