Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
07.14.2009, 12:48 PM
I think running 6s is a bit excessive personally. With 4s there is more power is on tap that can be used when bashing anyway ?
I have 5 M.M.M. and a couple have had hundreds of runs using 4s with zero issues, I have several friends whom like the 5s & 6s with their trucks and these guys have problems occasionally. Usually heat issues and other minor stuff,no smoke letting (yet).
When we are out running together even though they have more power on tap they can't use it because of where we run,surface,obstacles ETC you just don't get a chance to wring it out.
The Castle ESC is a awesome affordable controller but I beleive a lot of extra care and consideration to the set up has to be made to run reliably with 6s to do it with no heat issues and do it safely. Then theres always the luck of the draw that some of these guys who run 6s might have a defective ESC, shit happens.
