Thread Tools Rating: Thread Rating: 4 votes, 2.00 average. Display Modes
kalex0353
07.17.2009, 07:19 PM
Originally Posted by marl226 View Post
I was finshing up my new RC8Te truggy build and when i was mounting the motor a Mamba Monster 2200kv that's where the trouble started. it seem's like the 2200kv is to big for the RC8Te's motor mount or something is wrong. There's a pad that is recommended to put under the motor area but the motor's heat fins are pushing agaist the pad and almost cuting it throw to the chassis. i afraid to remove the pad because the motor and chassis may get damaged hitting each other. My question is has anyone esle had this problem and is there anything i can or should do about this because it just don't seem right? i have another question if someone could help. My RC8Te kit came with zero offset wheels and i allready have a set Proline's 1/2 offset wheel's with tires. would that be to much of a offset when the RC8Te's hubs are extended allready? i am new to the 1/8 scale truggy world.
Thank's
Team Associated RC8Te
Brushless Mamba Monster 2200kv motor
MMM esc
4s 5000mah lipo
I had the same problem. I put 4 thin (about 0.040) brass washers (on the 4 screws) between the center diff and diff riser.
Tags
buggy, hpi, losi, traxxas, truggy
