MetalMan
MetalMan's Avatar
07.18.2009, 02:33 AM
What I would do with ESC settings: 30% punch control and 3.2-3.3v/cell LVC, both of which should help out with heat.
As Snipin_Willy pointed out a poor solder connection (not necessarily your fault) can cause issues, especially heat related issues.
Other than that, does air flow well through the body?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.18.2009, 03:12 AM
First of all, I am running the same motor, except finned version on 6s lipo in a Revo 3.3, and after a 30 min main the motor temp was 130F, verified by two different temp guns (cuz I didn't really believe it). The Revo is quite a bit heavier, but I also have better airflow, and a finned case...
I don't really know what else you could do?
BTW, is that tape on the motor to hold the Neu end bell cover on?
