zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.19.2009, 11:24 PM
Originally Posted by fastbaja5b View Post
I don't doubt that, and if I felt the MMM was up to running a 5s/6s set up reliably I probably would.
But I don't think it is, the failure rate on 5/6s as against the failure rate on 4s is simply far too high!
What do you mean the failure rate is too high? For which cell range?
Like Linc said, the higher the voltage the better, I would be running a 45 volt setup (as 45 volts is around the limit for break-down through your outer skin layer) if there were the appropriate ESC available to the market.
