Hmm, i don't think so. I put a pinion i had laying around which is very close to 1 mod where the motor shaft should be and it reaches easily.
I see that Tekno stock a range of "long" pinions which are double hardened. They seem like the way to go.
It just takes so long to measure, drill, tap, file, cut, sand and polish to make another mount. If this one doesn't work the next step is the RCM mount.
