watterproof BL esc for a maxx on 4s???
whitrzac
Can't catch this...
whitrzac's Avatar
watterproof BL esc for a maxx on 4s??? - 07.16.2009, 10:32 PM
I was thinking of makeing my maxx into a winter basher, I reallly want to keep it BL....
it needs to run a tekin 2250 truggy motor on a 4s lipo
needs to be watter proof
needs proportional brakes
doesn't need reverse
needs to be <$150
any sugestions??
nitrostarter
nitrostarter's Avatar
07.16.2009, 10:54 PM
You can take a MMM and encase it in epoxy...
N. Rustler conversion
whitrzac
Can't catch this...
whitrzac's Avatar
07.17.2009, 12:45 PM
and when it fails....
nitrostarter
07.17.2009, 12:51 PM
buy a new one.
You could get a nice tupperware and mount one in there. Seal up holes for the wires to exit.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.17.2009, 01:17 PM
MMM has a coating on the electronics that should keep it "water resistant". Just blow er, spray er with WD40, the blow her again and she should be good.
nitrostarter
07.17.2009, 01:18 PM
Yes, but I wouldn't suggest submerging it in water this way...
07.17.2009, 01:21 PM
Or add some corrosion x to the board, pack the case with dielectric grease and say a prayer before you go out.
I was wondering if taking one of those flexible freezable cold wraps and putting it around the motor would do any good? Kinda off topic, but that could be handy for someone doing a shorter run or race. Takes a while for my head to get the wrap warm, not sure on a motor though...
hemiblas
hemiblas's Avatar
07.19.2009, 10:28 PM
If you can find one, the old Mtroniks truck ESC speed controls were completely waterproof. Not sure how it would run that motor though, but a 7XL smoked mine and they are supposed to be good for an L motor. They were only rated 80A, but with the motor that came with the setup, it was enough to move an emaxx pretty descent.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.19.2009, 11:59 PM
Get MGM .. I've had luck with mine in the winter months... i
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
whitrzac
Can't catch this...
whitrzac's Avatar
07.20.2009, 12:32 AM
I saw one of those a few months ago, the guy wanted somthing like $80 for it though...
hemiblas
hemiblas's Avatar
07.21.2009, 01:03 AM
They are good controllers, just a bit outdated. Only downfall is 5V on the servos instead of the new controllers that are higher. They are also a bit funny and you have to watch out as when you turn them on they look to calibrate the radio every time. I've had a couple of issues not paying attention pressing slightly on the trigger during calibration and then having the vehicle go WOT on me.
I think they pared them up with an 8L motor from the factory. Still cant figure out why a 7XL would smoke it so I would be a bit worried running it on a large motor.
07.21.2009, 02:40 AM
Something to do with the fact a 7xl can pull 100amps easy...
07.21.2009, 02:54 AM
Why are you dead set on a T8 2250 motor?
Gee
A Horse's Ass
Gee's Avatar
07.21.2009, 04:24 AM
What about the Mamba Maxx w/ a bec? I run it with a the Neu 1515 1y on 4s all year around in my G3R. Unless there is something about the motor you are wanting to run that doesn't work on the MM controller.
whitrzac
Can't catch this...
whitrzac's Avatar
07.21.2009, 10:11 AM
yes, I'm not buying another motor...
