E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.21.2009, 03:48 PM
A couple more points
1: What is the ambient air temp? If it's ~100*F, that's actually not a bad temp
2: Temps that rise fast but do not get much higher is nothing to worry about, as long as the temps don't keep climbing higher and higher. For a given surface area, any material can dissipate so much heat. The hotter it gets, the faster it dissipates (up to a point of course). At some point, the rate at which the temperature increases will slow and stop as there will be a balance between the delta between ambient air temp/material temp, and the rate at which the motor case dissipates heat. Also, fast rising and falling temps simply means there is efficient transfer of heat.
3: High ESC temps usually means overgeared. I know you say you can't gear lower due to physical constraints, but is it possible to increase the spur size? Or maybe get a diff ring/pinion that is geared lower (not sure how the CRT is set up)?
4: Assuming you can do something to gear lower somehow, I personally would not get a 1600kv motor for 5s. Some may disagree. 1600kv on 5s is under 30k rpm, and when geared for ~40mph, may cause the ESC to stutter a bit at startup because the motor is spinning relatively slow per mph and the ESC may not be able to get rotor positioning feedback as easily at lower rpms.
Listen to Brian, he knows what he's talking about! Also I have a 36-70-1600 Medusa and a 1515 2.5D (1650kv) and run them both on 5s with great results. Low speed power is fine and top end is incredible! On my RC8T I can gear it down to at least 30MPH, I race with it geared 50/15 or about 35MPH, fast enough to pull on the nitros and slow speed cogging doesn't exist
