07.23.2009, 09:56 PM
I run a 4500kv neu 1509 on 2s lipo. Plenty for this little truck. I doubt you will be able to gear the 7700 motor low enough to not burn it up. Not much reduction between the primary gearing and the diffs... Plus 4wd will push the motor pretty hard. And a 5mm shaft motor is preferred, for strength.
