07.24.2009, 06:52 PM
Your charger is fine, no need to upgrade it really- I find its better to simply buy more lipos and swap them out as required during your session, rather than have a field charging station sat on the hood of your car charging lipos inbetween sessions (thats personal opinion though).
Thunder powers are right up there really, you will be hard pressed to find many that are better; Hyperion Gen3s are getting rave reviews so it would be worth looking in them at anyrate.
Nothing wrong with having a high C rating, the more the merier generally, just depends what your wallet or wife is happy with you spending..
Any lipo that can put out 120amps or more will be more than fine (mah x C rating / 1000 = )
If you could swing a 5s setup, that should get you long enough runtimes to make the longer A main, since with higher voltage you can/need to gear down, resulting in less current draw to make a given speed & power output, so that means more runtime overall (all to do with the total power available vs how quickly you use it up).
I would suggest looking in the truggy section to see what others are doing with similar setups.
