Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Mentat
Brushless Mentat
Mentat's Avatar
07.26.2009, 03:29 AM
Jetdry makes an excellent coolant if you plan on running something like that. I use to build custom PC water cooling kits years ago. Done lots of research and testing on what works the best. JetDry is by far the choice. Also you could consider a Peltier based cooling system, they work so well that u can even have ice build up on one side of the cooling plate. Some videos here
http://www.youtube.com/results?searc...q=0&oq=peltier
This is a good example here on what u can do with it.
http://www.youtube.com/watch?v=3fYUVsydMmA
Its funny because u can make power with heat with a device like this.
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
KaztheMinotaur
KaztheMinotaur's Avatar
07.26.2009, 07:14 AM
That amazing. Where do you get those little gems at?
So heatsinking the hot side is what brings it down to single digit temps? Wouldn't that be a little too much on the motor or ESC?
Would that run on a 2500mah 3S LiPo?
Mentat
Brushless Mentat
Mentat's Avatar
07.26.2009, 07:30 AM
yeah you can. they are available everywhere. they are also known as Thermoelectric coolers. www.newegg.com is one place. just google it
KaztheMinotaur
07.26.2009, 07:33 AM
There are a whole bunch on Ebay also.
The boat ESC I bought has large heat sink on it...I could just lay the cold side right on the heat sink. Right?
You could put one on the motor also but you couldn't cool as much of the surface area of the motor since it isn't flat...
I found some that use 45.6 watts. How much amp draw is that at 12V?
Mentat
Brushless Mentat
Mentat's Avatar
07.26.2009, 07:38 AM
yeah that would work
KaztheMinotaur
07.26.2009, 07:44 AM
I was editing my above post while you were applying but I think I answered my self.
If I am reading the product specs properly then that one draws 3 amps. The larger 136.8W one draw 9 amps.
http://cgi.ebay.com/45-6W-TEC-Thermo...3A1%7C294%3A50
http://cgi.ebay.com/136-8W-TEC-Therm...3A1%7C294%3A50
That is a little less than what it calculates out to be...
lydiasdad
07.26.2009, 10:05 PM
tower sells these. draws 3 plus amps @12v. http://www3.towerhobbies.com/cgi-bin...C%2FB%3Eectric
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.26.2009, 10:51 PM
A peltier plate? And why would you want condensation?
zeropointbug
Z-Pinch racer
07.26.2009, 10:54 PM
James, that looks great! I have always wanted to do something similar, but at some point it gets too complex and heavy for the average Revo truck... the esc in a sealed box is what I'm talking about.
The Europe made mini pump/radiator system that emaxxnitro posted would work IMO. That thing popped onto the forums 2 years ago IIRC, no one as far as I know has used it, here anyways.
Ryu James
Ryu James's Avatar
07.27.2009, 01:14 AM
yeah, at this point i am still going to shoot for just using a fan and if that doesnt cool it enough then i will go with a liquid cooled setup like those ones on frozencpu.com. the peltier stuff is too foreign for me at this time. but i am thinking my esc/rx box with a 40mm fan is gonna be sufficient. we'll see i guess.
Jammin SCRT10 Neu 1512 1y
