Go Back   RC-Monster Forums > Support Forums > Novak
whitrzac
Can't catch this...
whitrzac's Avatar
07.26.2009, 09:54 PM
all novak ESCs will work with any sensored motor... the temp cutoff will only work on novak motors though...
add some caps and a fan on the esc and it should be fine...
ta_man
07.29.2009, 06:11 PM
Sorry, no.
The Havoc ESC specifically will not run a motor without a working temp sensor (unless you have kluged a resistor setup on the sensor cable). I know this from experience because I have a SS5800 motor with a failed temp sensor and the Havoc gives the LED error code for "no temp sensor" with this motor. It will not run it.
NovakTwo
Senior Strategist
07.29.2009, 08:20 PM
Originally Posted by ta_man View Post
Sorry, no.
The Havoc 2S and 3S and the HV Pro all have the "blue wire software". The Goat 2S and 3S Crawler escs have a different sensing program to detect whether or not a Crawler motor is being used. If not, the esc reverts to standard configuration, not crawling.
Novak Electronics, Inc.
whitrzac
Can't catch this...
whitrzac's Avatar
07.29.2009, 09:08 PM
Sorry, no.
interesting....
