13btoyrota
07.27.2009, 03:31 AM
Sorry new to this and not sure what the KB motors are ? [full name].
I am only going to be running 14.8v on it so it will only be doing 29 to 30,000rpm's. Its for a caster converted zx-1 nitro buggy with a 13/46 pinion and spure.
florianz
07.27.2009, 04:51 AM
those are the kb45xl or l motors of hobbyking.
littlegiant
07.27.2009, 06:06 AM
Hi, please avoid the KB motors. They are very inefficient. They heat up alot even with powerful fans. i run a KB45L 2300kv motor in my 4.7Kg truck geared to 35 - 40mph on 4S lipo and the motor will heat up to 60C within 5 min. Powerful but inefficient. And heat will demagnetise the motor rendering it useless. Go for better motors.
florianz
07.27.2009, 06:34 AM
thats right, they get hot easyly. I think the quality is slightly better then the pink kd motors, as the rotor is balanced.
if you need such a big motor and you're on a budget, go for the feigao 580l. it measueres about 44x74 mm, has an 5mm axle. it's not a lehner, but at least better then a kb45. some people are quite happy with the kb45, I think that their quality really varies from average to very poor.
the feigao has some cooling-holes, just put a nylon mesh over it to keep the motor free from stones, dirt.
