saucisse
saucisse's Avatar
07.29.2009, 11:03 AM
Originally Posted by legend15x3 View Post
Like the layout.
Just wonder if have a problem with nose diving off jumps? I have an LX1 also with ezrun150 and workig on a new motor since the last one the motor screws stripped. I am also running the nylon spur which is a 51 tooth and 13t pinion. Also, i fear my motor mount is bent forward after a hard crash that stripped the screws.
Did you need to space the motor mount up for the spur you run?
I don't have any nose diving at all. I'm currently running with the stock metal spur gear and no needs to space the motor mount.
____________________________________________
I don't suffer from insanity, I enjoy every minute of it !!
