I'm gonna miss the 3/16 shaft of the medusa 36 50 for 1/10th. I agree some quality 4 poles in this size would be awesome I own 4 medusas in that size. I wouldn't mind trying a comparble neu but I don't think they come in the small pinion shaft size I only see 5mm
You can order the smaller neus with 1/8 shafts. At least I vaguely remember being able to do that...
On the CC website you can change the 15xx series shaft size to 3.2mm, and I'm sure if you asked you could get a 14xx with a smaller shaft as they use the same rotor as the 15xx series. Some shops might carry the 3.2mm shaft also...
