wallot
wallot's Avatar
07.30.2009, 04:43 AM
I use default timing on the RX8 which is 10
I never said Tekin has not enough power its just lazy = the throttle curve is not linear as with Neu. neu will pull from standstill to maximum rpm smoothly. Tekin needs some time to spool up from low to mid rpms.
The start on Tekin is great but the acceleration is not what I need when exiting corner (mid corner exit whe I go from low to mid rpm). Sure this I can overcome by hitting throttle harder but then i would risk hitting it too hard and spinning tires.
This is how the motor response feels
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
