[QUOTE=phatmonk;309239]
Originally Posted by Bondonutz
The diameter of the wanna-be NEU in my truck is 37mm diameter X 48mm Long. I had to grind the little hump on the chassis that is over the center shaft in order for it to get a perfect gear mess with 50/28. There is also 1mm gap between rear shock tower and the rear of the can.
Is your setup using the stock motormount?And if so what other mods were required other than the above mentioned.
Stock motor mount, no mods other than previously mentioned.
Simple install with no fuss no muss. I do not drag race mine, I have it tuned for the track and bash and with this motor I have fantastic run times and zero heat issues. The hottest I got the motor was 127F and the ESC stays ambiant temp. Couldn't ask for more,
